If you want to add a sidebar in Woocommerce template, do it from here -> https://www.screencast.com/t/BgiKJTNRY
No, not in sidebar actually.
I was able to do it with pagebakery, insert widget to homepage area as an element
Bu tagdiv composer dont let me to add widget on an element area.
I wonder is there any tricky way to do it
or may be any other way to show some product on main area
Unfortunately, the Woocommerce cannot be edited with TD Composer and that’s why you cannot do this, sorry! Try to use the Woocommerce shortcode and place them inside a column text element to create your own desired layout. Check here -> https://docs.woocommerce.com/document/woocommerce-shortcodes/
