Woocommerce sidebar and footer problems
Hi Guys.
I’m including a classifieds section to my site using WPAdverts. https://progresohispanonews.com/clasificados_phn/
Everything was fine, but I have few question about it:
1. How can I use different sidebar to category classifieds page (How can I use the /clasificados_phn/ as teh URL)? – Same happends to product detail page
URL Category: https://progresohispanonews.com/categoria/abogados/
URL Product Detail: https://progresohispanonews.com/clasificados/clasificado-de-prueba/
2. In the same category page, the footer is completly damage
URL: https://progresohispanonews.com/categoria/abogados/
I Already fix the product detail page, please check the category page. Thx
Hello !
You can create a different template for each category using tagDiv composer: https://www.screencast.com/t/6D9KoXPvnB
Hi Vlad. But I just need a custom sidebar on adverts category, its is possible?
If this is a normal category and you do not use a cloud template for that category, then you can assign the sidebar from theme panel as global or individual per each category https://i.imgur.com/OMUrso2.png
Now if that is ca Woocommerce category, then our theme do not have an option to can set more sidebars, sorry! You can do this only if you create the Woocommerce page with tagdiv compose using the Woocommerce shortcodes.
