Woocommerce stock problem
i’ve a stock problem in woocommerce, when someone order the stock still be the same. Does it can be related to the theme ?
I have checked this and did not found any issue – http://screencast.com/t/jRKtWpIx6D – http://screencast.com/t/Y0FPIYdyKUL – http://screencast.com/t/J4aJb0Clyg
Maybe it is a caching issue.
cashing from my browser or my dedicated server ?
Please clear all the caches, also check this only with Visual Composer and Woocommerce active and also check the Woocommerce settings for this. Also you can check the Woocommerce documentation – https://docs.woothemes.com/documentation/plugins/woocommerce/ as the theme supports Woocommerce, there are just few implementations for templates(for example add custom sidebar in Theme Panel..), the theme doesn’t alter the plugins settings.
So if you use cache plugin I suspect that it is the problem.
