WP Admin panel does not display
I activated the Newspaper theme, and now the WP Admin panel does not display at all. Only a blank white page. The live website will display, but not the admin panel. Same problem on different browsers and also mobile.
Hello bvanrij,
Please ensure that you are using the latest version of the theme (Newspaper 7.3) and also, the latest version of required plugins (Visual Composer 4.12 and Social Counter 4.1). This update should be made only via FTP because this is the surest method in this regard. If you are using some untested plugins, please try to delete all of them and install only the plugins that come bundled with our theme and rule out the conflicting plugins. So, if your problem is still there after this advice, you should try to make a new clean install from scratch and then check the results.
i have a problem too, sad
Hello thangdv,
If you have ensured that you followed all the above steps and if your problem is still there, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further inspect your setup page and also, so I will be able to provide a more accurate response.
