WP Memory Limit 40MB problems
I cannot increase the memory to 256MB.
I have performed the expected procedure by inserting define( ‘WP_MAX_MEMORY_LIMIT’, ‘256M’ ); in the wp-config.php file, but it doesn’t work.
Where do I go wrong?
Best regards
Have you increased the memory limit in the php.ini?
Thank you very much.
You have solved my problem.
A good evening,
You can close the ticket.
Hello @SGDLF,
I’m glad @theleaderdotinfo’s answer helped you solve your problem.
Have a nice day!
