I’m using this plugin for my ads: WP PRO Advertising System – All In One Ad Manager (http://codecanyon.net/item/wp-pro-advertising-system-all-in-one-ad-manager/269693), it works fine but when I put more than one ads on the header, they doesn’t appear (only on header).
My website : https://reference-muslima.fr/
I’m using the same plugin as well. A single header ad appears all the way on a WordPress blog. I don’t think there can be two header ads. But, if you still want to display two header ads, there’s a possibility of trying slider revolution with WP PRO to display two ads as slideshows on header.
I haven’t tried that yet but you can try tweaking that..
Hi, sorry my english. Is that the final solution? I’m with the same problem but I think that using iframe isn’t the best solution for performance reasons. Any advice?
