Our website is here. https://imgur.com/a/KUs31yO
Two languages by WPML.
We have some problem with WPML on the Newspaper theme.
Here is how we process different interface now.
Footer:
by Page in different languages.
Category template:
We CANNOT modify 2nd or other language category template, such as category background image. The 1st(main) language style will become messy if we work on it.
Request:
1. The theme panel config values should be saved individually for the different language interfaces. It seems all language interface used the same theme panel config.
2. How to apply the WPML on Newspaper themes in right(official ways). Request for update on your manual.
Best,
CL.
The category can be set from theme panel per language on individual category like this -> https://i.imgur.com/fRMV7Br.png -> https://i.imgur.com/kpfKEGn.png -> https://i.imgur.com/MdvW1Qc.png, but this will not work for the entire theme panel, also if you want to set a global category template you need to use the string translate -> https://prnt.sc/rzttja -> https://prnt.sc/rztww9
Here is one article for using tagDiv Composer with WPML -> https://wpml.org/documentation/theme-compatibility/create-multilingual-wordpress-websites-using-the-newspaper-theme-and-wpml/
What you can do is to use cloud templates from tagDiv Cloud library per each language. Also please provide some more details on what do you want to translate an we’ll try to help to achieve what you need.
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
Please note that due to the high amount of support requests anwers can be delayed up to 72hrs !
