www.example.com >>> example.com problem
Hi Tagdiv support; notdefteri.net is indexing but not index www . notdefteri.net the reason for this i think
css files on the site www. without using calling code. header.php need to fix, can you help me about problem
  • This topic was modified 10 years by webhoca.
problem is different hosting, wp-super cache, yoast seo plugins not problem but website index problem. notdefteri.net index but dont take index www . notdefteri.net example screen google webmaster tools http://www.screencast.com/t/qsxLRxMfhJy yandex http://www.screencast.com/t/9Mon4yakgU
can you help me about big problem!!
  • This reply was modified 10 years by webhoca.
Not theme related.
You should specify the proper www vs non www URL in your WP settings panel, and/or explicitly set that in your wp-config.php file.
You should set your site to serve ONLY one version of your site, either http://www.yoursite.ooo or yoursite.ooo and *not* both.
You should let Google know which version is the primary, preferred version in your webmaster tools console.
If you have mixed versions of the URL in your content, consider doing search/replace via your mysql phpmyadmin to replace all versions of the “wrong” iteration of the domain.
If you explicitly specify the URL in your wp-config.php file, then WP might automatically redirect any requests for one version to the other.
Hope that helps!
Make sure you tell Yandex, Bing, Google which *version* of your site you will be using, and update your settings to match. Only YOU can do that. Theme doesn’t manage the URL.
