we get problem bewteen Yoast and tagDiv Composer plugins.
Activating tagDiv Composer plugin the Yoast panel where set all the seo setup disapper.
Tried to downgrade to Yoast 15 but the problem still there.
Deactivating tagDiv Composer plugin Yoast panell works.
We get serious problem also with duplicate description
Did you have a solution? Without unistall Yoast SEO?
Please provide some screenshots with what settings are displayed when tagDiv Cloud Library is disabled because I made a test, and for me are showing all settings from Yoast Panel with tagDiv Cloud Library activate.
Also, did you do a test using only tagDiv plugins and Yoast plugin?
Hi the problem is not with “tagDiv Cloud Library” plugin but with “tagDiv Composer” plugin as i wrote you in my ticket.
When tagDiv Composer plugin is enabled the yoast section “Aspect of research” is empty and I can’t reach any setting.
https://drive.google.com/file/d/1pXuc16GZ12txD7v5_ei6_vej1cgXJx_L/view?usp=sharing
If I disable the plugin Yoast setting are enabled but the site aptect is broken.
If i disable all the plugins except Yoast & tagDiv Composer nothing change
We would like to inspect this issue, so please make a full backup, send an email at contact@tagdiv.com and provide wp-admin and Cpanel access, so we can investigate more into this issue. Also paste a link to this topic so we can easily identify you.
Just done.
We have activated a stage site and sent you a email message with the credentials
Waiting for your response
