Yoast SEO Premium not recognizing inbound/outbound links, subheadings, etc.
I wasn’t having this issue before, but my Yoast SEO plugin is no longer recognizing links, headings, or phrases in my content. I’ve reached out to them and they weren’t aware of any issues. I just wanted to check in here to see if there is something that I did wrong. I’m running the most recent version of the theme.
Now there should be no problems with Yoast SEO in Newspaper 10.3, indeed in previous versions were some problems.
Also make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv Composer, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
If there is still a problem, please provide some more details and some screenshots.
Let me know the results!
It’s definitely something that is happening if you use Gutenberg. The way I get around it is to Save the article, go back to all posts, click back into the article, and then Yoast should recognize the links. This probably should be looked into more.
