Your page does not contain any H1 headings (need help)
Dear, i have a problem with my new web site
http://www.storypickers.com
When i do a search at SEO checker it tells me:
“””Your page does not contain any H1 headings”””
How can i add h1 headings at my foront page, and at my posts?
1
Waiting for you reply, wish to you all the bests
Posts have h1 tags.
Home page you can simply either create a new row, which can be at bottom of page, or you can even create a text box at bottom of a home page sidebar.
For instance you could do what we do, add text box widget and then in that box put h1 wrapped short description of the website for SEO. Works. 🙂
If you want a custom text/color you can make a new class and do something like this in a text box/widget
<h1 class="homeyh1">Snazzy SEO description of my fancy coolio whacky website here for SEO and search. Love me, why won't you love me?</h1>
Hope that helped!
Hi Chris, thnx for your reply.
I’m really sorry but im kind of new in these things. Please explaind to me better this part:
-how can i create a new row which can be at bottom of page
-how can i create a text box at bottom of a home page sidebar
– how can i add a text box widget at my home page with the describption of the web site?
Sorry for my ignorance!
setup a custom sidebar for your home page if you don’t have one; add a text box widget from the appearance > widgets section in WP admin panel.
If you’re using visual composer for custom home page, see the how-to in building home page; create new horizontal “row” at bottom of all the other content. If you can’t do that, simpler to use a text widget in sidebar.
See the docs for how to create a new home page sidebar; you can then set that sidebar to be used in your home page layout.
But those are the broad strokes — worth playing with a bit to experiment.
Note you can make a new home page layout and mess with it, preview, etc. without actually making it live.
TagDiv support can likely help with more step-by-step; this was just an overview of one way to do it 🙂
You was so clarify now.Thank you very much.Maybe i will se you see you soon in my next topic, how/what is? :p
