Your Site is Experiencing a Technical Issue (need help here)
HI team our website has critical issue today. please help
Here are the message from wordpress :
Since WordPress 5.2 there is a built-in feature that detects when a plugin or theme causes a fatal error on your site, and notifies you with this automated email.
In this case, WordPress caught an error with one of your plugins, tagDiv Composer.
When seeking help with this issue, you may be asked for some of the following information:WordPress version 6.0.2Active theme: Newspaper (version 11.5.1)Current plugin: tagDiv Composer (version 3.4 | built on 12.05.2022 9:11)PHP version 7.3.33
Error Details=============An error of type E_COMPILE_ERROR was caused in line 167 of the file /home/interna1/public_html/wp-content/plugins/td-composer/td-composer.php. Error message: require_once(): Failed opening required ‘css-analyze/css-analyze.php’ (include_path=’.:/opt/cpanel/ea-php73/root/usr/share/pear’)
Hello @amazone!
Please update the PHP version at least to 7.4 and check the results.
it’s done. thank you
