Youtube video background does not work for on versions newer than 12.6.3 for me
In version 12.6.3 and earlier it works without problems. I have tried versions 12.6.4, 12.6.5, 12.6.6 and RC12.6.7 without making any changes and the video stops working.
Thanks in advance if anyone can help.
Please let me know how you added the video and if you have an active YouTube API.
You can watch the video here: https://www.laneurosis.net/
As it plays I understand that there is no problem with the API key. If I update it stops playing.
I just checked and the video is working -> https://we.tl/t-d6K1DIPk4Q
Yes, it works because version 12.6.3 is now installed as I have already explained. The problem is that when I upgrade to a newer version it stops working and I have to go back to this version.
As you can see in this video, it works on my end https://we.tl/t-gA6NiR8b9u. Please try to do a staging and check if you still have the Youtube API after the update.
I’m going to send a video to the contact email where I think you can see the problem.
Ok. The email address is contact@tagdiv.com
Anamaria, I have the same problem with video in background on http://www.gmstrategia.it
Hello @ghedamalbert !
– admin url and credentials
Thanks !
