After updating to 4.1, videos not showing properly, Please check – http://goo.gl/YMjKW7
It shows black block, before updating theme, player was fitting properly to height of video, now not showing properly
Do you still have this issue? Seems to me like your video is showing fine, the same way it’s displayed on YouTube
Are you referring at this black block? http://screencast.com/t/HbrbvPRtSS
If you are still encountering this problem please try to update to latest theme version 4.2 also try to disable the speed booster plugin if you are using it.
Please let me know.
