Zoom out problem
Hello
I have a problem when I open my website its zoom out I don’t know what the problem?
You can try this fix
#td-mobile-nav {
position: fixed;
Paste the code in Newspaper>Theme panel>Custom code>Custom css
But also is possible to be others elements broken in RTL
Our theme was does not support RTL so simply changing the direction will not work properly. Lots of theme elements have to be adjusted for the thee to support RTL.
#td-mobile-nav {
position: fixed;
