Home User profile
tagDiv Member
2B-On
tagDiv Member
Top Bettina!
2B-On
tagDiv Member
Hello Bettina,
I disabled both, but it’s still active on the Homepage. I send the file with the indicated area to validate, if we are talking about the same area.
https://www.dropbox.com/s/pvcdjuzn2br57ed/ligacombatentes%20org.pdf?dl=0
JG
2B-On
tagDiv Member
2B-On
tagDiv Member
But this is the block I can’t select to edit on the home page, next to the footer, how can I hide it?
2B-On
tagDiv Member
Hi Ana Maria
I already questioned it, and no one says they did it, but what is certain is that it was there! Thank you very much, it seems to be solved!
JG
2B-On
tagDiv Member
Hi Ana Maria,
We made no code changes. Plugin updates only. We have already visited Theme Panel -> Analytics/ Js code and all fields are empty.
Best Regards,
João Geraldes
  • This reply was modified 3 years by Anamaria. Reason: Delete the access
2B-On
tagDiv Member
Hi Ana Maria,
Regards,
JG
2B-On
tagDiv Member
2B-On
tagDiv Member
Hi Ana Maria
Good morning,
Thanks for your reply.
We already used the SEO Yoast plugin, but the problem was the same.
We’ve already resorted to tool => https://developers.facebook.com/tools/debug/ and the problem reported is the facebook id that the SEO Yoast plugin says it doesn’t need.
That’s why we turn to you.
