Thanks for getting back to us.
Much appreciated, Alex.
Hi Bettina,
It’s a theme issue, the fault is also on your current live demo. Only specific demos. Like your parenting one.
https://demo.tagdiv.com/newspaper_parenting_pro/?s=and
All the images are different widths on desktop.Try looking through a few pages of search results.
As a quick solution, you can roll back to 11.4.1 until they fix this.
Newspaper (wordpress menu) > Updates > Newspaper time machine > Select 11.4.1
I have done this for now.
I would like to add, I am getting the same issue but for the rest of my pages (categories, search page etc.)
https://www.gymtechreview.com/?s=reebok+jet+100
In the DivTag builder you can set the image height and image width (percentage based). It looks like something has gone wrong here, it should be minimum image height and width, not depending on the image size and width of your initial image. Which is why they are all different sizes.
I can fix this with CSS, but it would mean writing it all again for desktop/tablet/mobile, but there should be a fix for this soon.
It’s also an issue on your demo theme.
The images are all different sizes.
