Home User profile
tagDiv Member
Amar_work
tagDiv Member
Amar_work
tagDiv Member
Yes. we installed one plugin – JS Jobs Manager, but due to some reason our menu pages are not displaying desired posts and template also changed.
http://healthcarechronicle.com/category/knowledge-e-corner/
In this page blog posts are displaying instead of knowledge e-corner.
Can you please look into and show some solution.
Amar_work
tagDiv Member
HI Simion,
Solved the problem..thank you.
Actually we installed member pluggin, thats why overighed settings. now changed the settings.
Now running fine.
Thank You.
Amar_work
tagDiv Member
I gone through the provided link in documentation, but im unable to create that menu.
As explained in forum-
in image 2-
“make this category a mega menu” drop down not appearing when i adding category in menu??
Pls look into this. If u need credentials let me know.
