Home User profile
tagDiv Member
E_Normus
tagDiv Member
E_Normus
tagDiv Member
Hello Catalin,
Thanks for the info! I’ll check out the links you suggested and go from there.
Awesome Theme by the way. You guys have done a phenomenal job!
E_Normus
tagDiv Member
Thanks for your help thus far!
Unfortunately, the problem still exists. I have WP Super Cache turned off. Does that need to be on in order for this to work? I ask this, because I just recently turned it off to utilize the 7 Day Post Sorting feature. Since then, I have been having trouble with the Youtube API. Would you recommend I use another method if available?
Thanks Again!
E_Normus
tagDiv Member
E_Normus
tagDiv Member
Thank You!
You’ve been an awesome help.
Happy Holidays!
E_Normus
tagDiv Member
Hey Catalin,
Last thing, I noticed that on the mobile version of the video template (I’m using style 10) the youtube videos are not as crisp/hd as the desktop version. Is there a way to fix that? Do videos on the phone not play at 720p60/1080p60?
Thanks Again!
  • This reply was modified 8 years by E_Normus.
E_Normus
tagDiv Member
Hello Catalin,
I got it working for both desktop and mobile. You pointed me in the right direction, Thanks!
desktop header
mobile header
E_Normus
tagDiv Member
Hey Catalin,
The website is cavenation.com and this is the header situation I’m talking about. I want to make the header background look like the second image.
header background
Thanks Again!
E_Normus
tagDiv Member
Thank You!
