Home User profile
tagDiv Member
Lasyte_Solutions
tagDiv Member
Thank you for the reply. I am implementing the changes as suggested. However, I have come across a weird scenario where my website that is running this theme is showing up over 26 errors when we click on inspect element through a Chrom browser. Can you please help me fix these errors? I am attaching a screenshot of the same.
http://www.screencast.com/t/eLvdL4tjU
Your help in this regards would really be appreciated.
Lasyte_Solutions
tagDiv Member
Caitlin,
Thank you for your prompt response. I have attached three screen shots. The issue we are having is for certain sections it is rending the full size image instead of the small displayed size. For example, it’s loading the full size 1000 x 900 pixel image. Instead of a 200 x 180 thumbnail. If you have come up with a theme fix, or how I can manually fix the HTML / CSS /JS code in the theme. Thank you.
Screenshot of correct Code: https://prnt.sc/imyjys
Screenshot of incorrect Code:https://prnt.sc/imykj3
Screenshot of incorrect Code:https://prnt.sc/imykv4
Jesse
Lasyte_Solutions
tagDiv Member
Hello
I have come up with a weird scenario. On my website http://coloradowebsite.design/dev/Leafbuyer/blog/ …. some of the images are showing the srcset tag for thumbnails while some are not. Can you please help me to understand why is this happening? I want srcset tag for all the images on my website.
Jesse
