Will do,
Thank you
Hi Catalin,
We did not use an events plugin for the site. We just created a post category called events are are clicking on it when we want it show up in the events section. Where are you trying to access the site from? or rather what ip? our server might of blocked it by accident.
Thanks,
Hi Catalin,
Just did as you instructed, I deactivated all plugins except for VC and WP Super Cache (to clear the cache) and it didn’t help.
The site is http://yoursauga.com/ there is suppose to be 3 events in the bottom left section but only 2 are showing. The posts are properly labeled and the event category is checked. The filter is set to show the category event / latest.
Thanks in advance for you help in the matter.
