Home User profile
tagDiv Member
max.dreisbusch
tagDiv Member
that’s it 🙂 I had one step missing, did not click on the new displayed menu and then the top zone
Thanks a lot for your great support 🙂
Best wishes Max
max.dreisbusch
tagDiv Member
Hi Simion,
a lot of thanks. That was the case for the really small theme, now the two spaces are left for tablet portrait and landscape mode.
I already had a look at the zone settings, it is empty as you can see in the screenshot attached. Also with the value “0” there is a space.
I have not seen a possibility to change 🙁
https://prnt.sc/ubm5q4
Have you got any idea for this mode?
Thanks and best wishes
Max
max.dreisbusch
tagDiv Member
Hi, sorry for that.
the website is currently located under https://neu.tcs-aschaffenburg.de
I can not find any element making this space possible in the inspector. Would be great if you do so
Thanks in advance
max.dreisbusch
tagDiv Member
I made a short video here: https://nextcloud.max-dreisbusch.de/index.php/s/ZenEJScHgmN9WSi
Password is TagDiv2020!
max.dreisbusch
tagDiv Member
So this is the error message shown in the ui: Invalid data Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)
And this one is from console: backend.min.js?ver=6.2.0:10 Uncaught TypeError: Cannot read property 'data' of null
at Object.<anonymous> (backend.min.js?ver=6.2.0:10)
at i (load-scripts.php?c=1&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4.2:2)
at Object.fireWith [as resolveWith] (load-scripts.php?c=1&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4.2:2)
at x (load-scripts.php?c=1&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4.2:4)
at XMLHttpRequest.c (load-scripts.php?c=1&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4.2:4)
(anonymous) @ backend.min.js?ver=6.2.0:10
i @ load-scripts.php?c=1&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4.2:2
fireWith @ load-scripts.php?c=1&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4.2:2
x @ load-scripts.php?c=1&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4.2:4
c @ load-scripts.php?c=1&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4.2:4
XMLHttpRequest.send (async)
send @ load-scripts.php?c=1&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4.2:4
ajax @ load-scripts.php?c=1&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4.2:4
processImages @ backend.min.js?ver=6.2.0:10
media.editor.send.attachment @ backend.min.js?ver=6.2.0:10
(anonymous) @ media-editor.min.js?ver=5.4.2:2
(anonymous) @ load-scripts.php?c=1&load[chunk_0]=hoverIntent,common,hoverintent-js,admin-bar,underscore,backbone,shortcode,thickbox,wp-util,wp-backbone,media-models,wp-plupload,&load[chunk_1]=jquery-ui-sortable&ver=5.4.2:11
v.map.v.collect @ load-scripts.php?c=1&load[chunk_0]=hoverIntent,common,hoverintent-js,admin-bar,underscore,backbone,shortcode,thickbox,wp-util,wp-backbone,media-models,wp-plupload,&load[chunk_1]=jquery-ui-sortable&ver=5.4.2:11
(anonymous) @ load-scripts.php?c=1&load[chunk_0]=hoverIntent,common,hoverintent-js,admin-bar,underscore,backbone,shortcode,thickbox,wp-util,wp-backbone,media-models,wp-plupload,&load[chunk_1]=jquery-ui-sortable&ver=5.4.2:13
p @ load-scripts.php?c=1&load[chunk_0]=hoverIntent,common,hoverintent-js,admin-bar,underscore,backbone,shortcode,thickbox,wp-util,wp-backbone,media-models,wp-plupload,&load[chunk_1]=jquery-ui-sortable&ver=5.4.2:13
f @ load-scripts.php?c=1&load[chunk_0]=hoverIntent,common,hoverintent-js,admin-bar,underscore,backbone,shortcode,thickbox,wp-util,wp-backbone,media-models,wp-plupload,&load[chunk_1]=jquery-ui-sortable&ver=5.4.2:13
l @ load-scripts.php?c=1&load[chunk_0]=hoverIntent,common,hoverintent-js,admin-bar,underscore,backbone,shortcode,thickbox,wp-util,wp-backbone,media-models,wp-plupload,&load[chunk_1]=jquery-ui-sortable&ver=5.4.2:13
n.trigger @ load-scripts.php?c=1&load[chunk_0]=hoverIntent,common,hoverintent-js,admin-bar,underscore,backbone,shortcode,thickbox,wp-util,wp-backbone,media-models,wp-plupload,&load[chunk_1]=jquery-ui-sortable&ver=5.4.2:13
_onModelEvent @ load-scripts.php?c=1&load[chunk_0]=hoverIntent,common,hoverintent-js,admin-bar,underscore,backbone,shortcode,thickbox,wp-util,wp-backbone,media-models,wp-plupload,&load[chunk_1]=jquery-ui-sortable&ver=5.4.2:13
click @ media-views.min.js?ver=5.4.2:2
dispatch @ load-scripts.php?c=1&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4.2:3
r.handle @ load-scripts.php?c=1&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4.2:3
js_files_for_wp_admin.min.js?ver=28832a33217c23aa6f76cdf3fc3c1388:15 Uncaught Invalid data Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)
showNotice @ js_files_for_wp_admin.min.js?ver=28832a33217c23aa6f76cdf3fc3c1388:15
notice @ js_files_for_wp_admin.min.js?ver=28832a33217c23aa6f76cdf3fc3c1388:14
(anonymous) @ js_files_for_wrapper.min.js?ver=28832a33217c23aa6f76cdf3fc3c1388:459
window.send_to_editor @ js_files_for_wrapper.min.js?ver=28832a33217c23aa6f76cdf3fc3c1388:458
insert @ media-editor.min.js?ver=5.4.2:2
add @ load-scripts.php?c=1&load[chunk_0]=jquery-core,jquery-migrate,utils,moxiejs,plupload,jquery-ui-core,jquery-ui-widget,jquery-ui-mouse,jquery-ui-draggable,jquery-ui-&load[chunk_1]=slider,jquery-touch-punch,iris,wp-color-picker&ver=5.4.2:2
