Home User profile
tagDiv Member
mo-tech
tagDiv Member
Hi Lucian,
My issue is not with the thumbnail itself. It’s with the way it centers it.
The ?resize=326%2C159 is not part of the filename.
It is a line of code added by WordPress or by your design, I am not sure.
The example you show is exactly the issue I am referring to.
Where is the ?resize=326%2C159 coming from. and how do I recenter the image
  • This reply was modified 12 years by mo-tech.
mo-tech
tagDiv Member
Thank You Lucian
I disabled my CDN and the same issue persists.
The theme to be really forcing a ?resize=326%2C159
I am sharing my site with you through this
I would’ve preferred PMing it to you but it seems like we cannot
mo-tech
tagDiv Member
@Lucian I must admit you gave the BEST and WORST response possible.
The best: simply because you admitted that
“Unfortunately we can not offer support for WPML”
which basically tells me to stop asking questions with regard to WPML.
The worst: because I purchased your theme, purchased WPML, invested HOURS to configure everything to be only let down that you will
remove the WMPL compatibility statement from theme’s presentation page
as well as
If you are unhappy with our theme we can offer you a refund.
I know where I stand now, I have no real choice but to continue developing on what I have, I have invested too much time to switch themes now, and WPML is at least supported by their developers whereas qTranslate has no guarantees since it’s free.
@virtualida
I would definitely appreciate any help you can give me, we can keep it here in an open forum or switch to PM, whichever you prefer.
What I need to know is how to add the language bar to the MAIN MENU and have it take the proper CSS styling. Have you done that?
mo-tech
tagDiv Member
Im in the same situation here.
I didn’t know about qTranslate before purchasing WPML for 199$! since I saw on themeforest
Compatible With
WPML, BuddyPress 1.9.x, WooCommerce 2.0.x, bbPress 2.5.x, Bootstrap 2.3.x
Only to find out now, that it is compatible but not supported.
I’m having similar issues as @virtualida with the menu selection of the different languages.
Where are we to put the Language selector? Can we get some assistance or a how to on this matter?
mo-tech
tagDiv Member
Nevermind I fixed the above issue, but now i have a new one
http://www.screencast.com/t/GbCwjmErfw
the SOURCE is now underneath the facebook comments box and not immediately after the post as it should be.
what is the issue causing this?
mo-tech
tagDiv Member
Excellent, it worked i downloaded the plugin you suggested.
It has automatically placed the comments box immediately after the post.
I disabled the Facebook plugin and but now the native comments box appeared.
Which means the original plugin places itself in the native box area.
Two questions:
Either how do I move the wordpress’ native comment box to be after the post so like this i can use the original plugin i had
or
how do i remove this box from appearing?
http://www.screencast.com/t/iD3odNZMxV
mo-tech
tagDiv Member
Thank you, I think a great feature would be to add a Custom JAVA area like you have a CUSTOM CSS area, just a thought.
Thanks again!
mo-tech
tagDiv Member
im interested, will you share?
mo-tech
tagDiv Member
@Manuel Fink
Great looking site!
I’m still developing mine but I noticed you are having a similar issue with the AJAX Infinite loading (maybe you haven’t noticed) when you reach the bottom of your page the AJAX loads the next series of posts only once, if you reach the bottom again it won’t load the next series, you have to go back up then back down.
I’m using FF30.0.
Any idea why?
