Viewing 1 post (of 1 total)
Hi, Simion C.,
Thank you for your reply. I believe I may not have explained my question clearly.
I already understand how to create a custom Single Post Template and assign it globally to all posts. However, I am concerned that replacing the current template could affect or break the existing post layout.
What I would like to know is whether it is possible to edit the STANDARD – DEFAULT template shown here: https://prnt.sc/CbwbATZjlZS3
This appears to be the default template currently used across all posts and seems to have been included with the theme. Please note that this particular template does not appear in the list of available templates under Cloud Templates.
Can this specific default template be edited or duplicated while preserving the current layout?
