Hi Calin,
Noted and understood.
We have successfully followed your advise and created custom header.
Hi Calin,
Thanks for response.
I have got it done from a professional php developer resulting in such a header layout: https://snag.gy/4w8JRA.jpg
I hope tagDiv developer team considers including the said header design layout in their future updates.
Regards.
Hi Simon,
So, is it possible to modify ...wp-content/themes/Newspaper/parts/header/header-menu.php and achieve the results as required for the header design layout?
Regards.
Kindly close this thread,
Ok Thanks for the info.
Regards.
Thank you for the info.
Regards.
