I did!
Thank you for your reply. I’ve sent all required information to contact@tagdiv.com
Well, the new Update is there, sadly still this issue isn’t resolved.
This reply was modified 3 years by
raketenaffiliate.
Hey, is this fix still in development?
So, there’s no solution or workaround at this moment? Sad, but alrighty. Gotta wait.
Alright, thank you for that, that at least makes it violet.
Still, on hover it’s getting gray again, so there somewhere has to be a css hover transition effect for the border-color. I would want to change that, with css. I just don’t know where and how to address this class. Could you help me with that? If not, maybe some other members here have an answer.
raketenaffiliate.
Again, this doesn’t work and I know why, this just styles the ICON BORDER,
I WANT THE WHOLE ICON BOX TO HAVE A PURPLE BORDER-COLOR ON HOVER:
As you can see, this gives the icon a border, the border of the white box surrounding it, still stays the same.
THIS is how it should look like on hover:
raketenaffiliate.
Hi Bettina, thank you for your quick answer, I just tried it out and it doesn’t work.
The border-color of the whole icon box should be violett, it’s still grey.
I marked the line in yellow to show you what i want to be violet (on hover only):
raketenaffiliate.
yes please add the h1-h6 option to text with the title please. Was searching for it too and just found this post.
Thank you for your quick reply.
First of all, I got it setup a bit cleaner now, thanks to your answer.
First, I uninstalled the mobile plugin and the omgf google fonts plugin, then I deactivated the “use google fonts” and “use default fonts” option in the theme panel.
Then I uploaded the fonts and added css to style.css from this link: https://google-webfonts-helper.herokuapp.com/fonts/comfortaa?subsets=latin
After then choosing the right fonts again in theme panel, everything seems to load properly, just SAFARI on my IPHONE shows times new roman, here’s a screenshot below. I tried google chrome mobile and it showed up just fine. Is there any Solution to this?
Also one more thing. How can I change the color gradient of the mobile theme menu to match my theme (no plugin, i use the mobile pages)?
This reply was modified 4 years by
raketenaffiliate.
