Thanks MIXVICE for the advice….it worked.
Using sFTP access, I first saved the PLUGINS folder as “disabled_plugins”
Then deleted the PLUGINS folder
Was then able to access the WP admin manager
Changed the name of “disabled_plugins” back to PLUGINS
All the required plugins reloaded and everything worked well.
I also no realize that I didn’t have a list of other plugins we had previously installed and so am having to review and reactivate the non-required plugins that were lost.
thanks for your help!
I’ll do that and show you what I mean!
Do you have an email so I can send you photos of the problem?
