Hi Bogdan,
thank you for your reply,
unfortunately, the custom URL link is not available for that specific page. It is available for other pages, but not the one I need it for.
Perhaps there is a toggle function that allows for you to input a custom link for a menu item?
Thanks,
Nick
You’ll see how in the first post “Share your Soccer Clips with us on Instagram…”
the bottom half of the feature images text which should read “#stouffvillesoccer” is cut off
Thank you for your response,
I ended up changing the settings for our current blog homepage to a different layout and the website is now exactly how we wanted – thanks again for your help!
