a few questions for front
Q1. For the single post, how to change the color for hyperlinks?
Some results has been found by seraching but the link is invalid – https://forum.tagdiv.com/topic/rollover-color-for-hyperlinks/
Q2. For Flex Block 4 > content length > excerpt length
You may refer to below image and find that the excerpt length is different, but both of them have been setted as “2”.
Could you please advise how to set it is the same.
Q2
Q3a. For banner section “big grid flex 2”, is it possible to specify a single POST for banner display?
I found that it only could select by “filter” but cannot by “post ID”
Q3b. For NEWs ticker, as questions as above. Cannot select the post by “post ID”
Q2
1. Copy-paste the link manually in a new tab.
2. Make sure you do not have a specific excerpt while you normally edit the post in the WordPress Editor and all the settings are the same like for the second block. Please check this guide: https://forum.tagdiv.com/excerpts-introduction/
3. No, because they are different than flex blocks elements. You can achieve this with a flex block, because you can set a limit in the general tab.
Documentation here:
– https://forum.tagdiv.com/flex-block-settings-guide/
– https://forum.tagdiv.com/big-grid-flex-settings/
You can add only some posts to the news ticker element: https://prnt.sc/HzFU_yRpvjWk
refer to Q3,
I just want to make the banner section in home page, example as above
https://www.jedinews.com (also using newspaper theme)
May I re-confirm which one I should use? Big Grid Flex or Flex Block ?
On this -> https://www.jedinews.com/ website the elements are those:
– https://i.imgur.com/8q28jUr.jpg
I hope this will help you!
thanks for quick reponse.
