A Few Tips for Newspaper X – Speed, High CPU Usage Issues
“What kind of host/server are you using? please note that using our theme, you need to have a good host with very good resources.”
Why do you not put that on your sales page then?
Hi CharityToday,
I think that this is a misunderstanding, those tips are if you use a slow host, then avoid using features that request admin-ajax (in our theme each block can have a pagination, but if you have a low host it will be recommended to use only for blocks you need, for example on post loop).
Do you have some problems using our theme? If yes, please let us know, this will help us to understand what can be the problems.
Also we have an article here https://forum.tagdiv.com/requirements-for-newspaper/ with the theme requirements and with references for host.
For some users is enough to make the steps from this guide https://www.wpbeginner.com/plugins/how-to-clean-up-your-wordpress-database-for-improved-performance/
Also you can not use a premium theme in a host with 1GB CPU and RAM, it will work slow, but once that you get visitors on your website it will work harder and harder.
For example here is an article with some decent hosting services https://tagdiv.com/bluehost-review-hosting-solutions/
Thank you for your understating!
When looking at my Google Analytics I have a lot of URLS with “?tdb_action=tdb_ajax” at the end. I’m assuming when you said ‘Remove AJAX viewcount’ this would remove that?
Is there a way I can find which features are requesting admin-ajax so I can remove them?
Hello @thefeedski,
I already replied to your own topic about the same issue, please check: https://forum.tagdiv.com/topic/what-is-tdb_actiontdb_ajax/#post-398792
This is an excuse not solution.
Viewing 5 posts - 26 through 30 (of 30 total)
