A problem occurred in Visual Composer.
After upgrading WordPress version 4.7.5–ja, a problem with Visual Composer has appeared.
Article posting is now blank.
http://www.fighters-spirits.com/magazine/archives/3051
http://fightersspirits.sakura.ne.jp/036.jpg
Does this resolve by downgrading WordPress?
Wordpress Version 4.7.5–ja
Newspaper Version 7.8.1
This is most likely a plugin conflict so please disable all plugins except visual composer, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
Even if you disable all plugins, the problem will not be solved.
Is it due to wordpress version upgrade?
Is it possible to solve by downgrading?
I upgraded wordpress, upgrade the plugin, upgraded the theme at the same time.
Is it because of it?
The settings of Visual Composer are as follows.
http://fightersspirits.sakura.ne.jp/037.jpg
http://fightersspirits.sakura.ne.jp/038.jpg
This should not happen when updating WordPress. You seem to be missing the post options and all other elements from the post edit screen. Also the settings form Visual composer seem to be set properly. Try updating the Visual composer editor to the latest version provided in the theme package
– https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
I succeeded in updating the Visual composer.
However, the article posting management screen is displayed correctly, but it is not displayed on the site.
http://fightersspirits.sakura.ne.jp/039.jpg
http://www.fighters-spirits.com/magazine_test/archives/3051
Is this because the Visual composer is not active?
http://fightersspirits.sakura.ne.jp/040.jpg
http://fightersspirits.sakura.ne.jp/041.jpg
http://fightersspirits.sakura.ne.jp/042.jpg
The trouble disappeared. So, when theme panel version was changed to 7.8.1.
Newspaper – Theme panel version: 8.0
Newspaper – Theme panel version: 7.8.1
*Plugin, wordpress version is the latest version.
Other plugins
TagDiv Social Counter
Revolution Slider
TagDiv Mobile Theme
In order to upgrade these also, should I install the plugin as a zip file after aninstalling it?
You need to deactivate and delete the old plugins and install the new ones from the theme package normally, in the plugins section – https://www.screencast.com/t/53nogg3VD
tagDiv Composer = tagDiv Composer
tagDiv Social Counter = tagDiv Social Counter
Visual Composer = WPBakery Visual Composer
Revolution Slider, what a plugins name?
tagDiv Mobile Theme, what a plugins name?
Once I know the name, I will uninstall the old plugin and install the latest version.
You can see the plugins name in the screenshot provided above
– https://www.screencast.com/t/v8e4jMTB
In the plugins section they look like this
– https://www.screencast.com/t/HgX1gnyUr
The following plugins were not included from the beginning.
tagDiv Composer
Revolution Slider
TagDiv Mobile Theme
TagDiv SpeedBooster
I think that the following was installed when updating the theme.
tagDiv Composer
When tagDiv Composer is invalidated, the character display is normal.
However, the image is not displayed.
http://www.fighters-spirits.com/magazine_test/archives/2309
The difference between the test server and the production server is whether the following plug-ins are not included.
Popup Maker
http://fightersspirits.sakura.ne.jp/043.jpg
Version
Test server Newspaper – Theme panel version: 8.0
Production server Newspaper – Theme panel version: 7.8.1
Popup Maker is in the test server, but it is disabled.
All other plugin versions are the same.
The custom CSS is below. It is described on the test server and the production server.
.widget_nav_menu .sub-menu {
display:none;
.td-category-header .td-page-title { text-transform: capitalize; }
http://fightersspirits.sakura.ne.jp/044.jpg
The production server same page.
Characters and images are displayed correctly.
http://www.fighters-spirits.com/magazine/archives/2309
I replaced the test server with the production server.
And updated the theme.
So, tagDiv Composer is installed automatically.
Since the same problem occurred, I was tagDiv Composer invalidated.
Currently only images are not displayed in articles.
Popup Maker is not installed currently.
The tagDiv composer was introduced in the latest theme update, it is our new front-end page editor. More information about this here
– https://forum.tagdiv.com/tagdiv-composer-tutorial/
– https://forum.tagdiv.com/visual-composer-tagdiv-composer-transition/
The images should display fine, usually image problems are caused by plugins. That causes in some cases the lazy load feature to produce this kind of issues. Please try it only with the bundles plugins, to see if the result is still the same. Or maybe deactivate the lazy load in the theme panel – https://www.screencast.com/t/HBjrb3Ln and see if that has any effect.
It was the setting below.
http://fightersspirits.sakura.ne.jp/045.jpg
However, the display is error with the site.
The following are installed and enabled now right.
tagDiv Composer
tagDiv Mobile Theme
tagDiv Speed Booster
The following capacity was large and installation was impossible.
Revolution Slider
There seem to be some errors still present on the page
– https://www.screencast.com/t/MNyTmntrO
Try leaving only Visual composer active, clear the cache and check the results. You could make a test by creating a new post and see if the issue is still happening.
Now it will display normally.
-Visual composer active
Is it due to competition between theme and plugin?
The following was confirmed.
-tagDiv Composer active
Disorder appears in character display.
Head Cleaner
Reshape the contents of the <head> of the WordPress site and the footer area.
This caused the image not to be displayed.
Now it is deactivating.
If you have been using Visual composer for the posts, problems like this could happen when the tagDiv composer is activated. You should leave it disabled for now, and use Visual composer.
Viewing 18 posts - 1 through 18 (of 18 total)
