Activation Problem.
Hello dear friend.
My name is Levon Turaç. Today I bought your theme and downloaded it through the envato market.
But there is no activation page in the theme.
Can you help me with this?
Therefore I can not download the cloud theme.
Note: My english is bad. I am use Google translation sorry ☹
https://ibb.co/1sS5bmv
https://ibb.co/kDd2FWZ
https://ibb.co/hMrfmpN
Thank you for your interest in our theme! The theme should have to be activated from the Theme panel, like this -> https://www.screencast.com/t/cObq8T1x2oZT For more details about theme activation, please check our documentation from here -> https://forum.tagdiv.com/newspaper-6-how-to-activate-the-theme/ Please note that until you activate the theme, you can not import any cloud template from our Cloud Library, sorry! Also, you can try the manual activation option. You will find it in the activation panel at the bottom of it like here: https://www.screencast.com/t/TvqW1Ck45, go to our manual page activation and you will be able to activate it:https://www.screencast.com/t/sJAKdWcV!
If you will encounter some errors and also, if you cannot activate your theme, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) and your Item Purchase Code so I can try to activate your theme.
Hope this helps!
Yes, I fixed the problem, thank you very much.
I have a different problem now.
I cannot change the ads content in the header section of the homepage.
I’m sending you a picture.
I set the header part from the theme panel. I didn’t install it as a cloud theme. And unfortunately the editing feature does not come out for this area.
Do I have to download header template?
https://ibb.co/Tm9hxmG
https://ibb.co/2PsC9y8
Please check in the Theme panel->Ads section, check in the header ad spot
http://prntscr.com/ob148t
Remove or replace the default ad code found there. Then save and check if the ad is removed from the header. If it’s still there, clear the cache if you use a caching plugin. Also force refresh the page where you are checking in (Ctrl+Shift+R). Let us know.
Thank you so much. My idiot 🙂 I’m very novice. I am really sorry.
I have another problem.
I’m adding social media blocks to the sidebar in the category.
But the options are only those in the picture. Although I fill in the options in the theme panel, it doesn’t appear in this area.
I would like to add twitch and steam connections to this part. How do we do that?
https://ibb.co/N3MNKSt
My Activate button is not working. What do I do?
@Modart Pc Glad it worked. Regarding the sidebar widgets, The wordpress customizer should work fine. Or you can edit the widgets in the Appearance->Widgets section. All the widget sidebars can be found there, and you can add/remove/modify them
http://prntscr.com/obxxfb
But unfortunately the social counter doesn’t currently have the socials you mention. I could add these as a request in our list and they will be considered. Sorry for the inconvenience.
@divaspathak
So you are having problems activating the theme with the license key. If you followed the guide – https://tagdiv.com/how-to-activate-the-newspaper-theme/ and there is a problem, we could take a look. Please send us an email at contact@tagdiv.com and provide the website, admin login and the activation key. Mention with more details the problem you are having. Let us know.
Please, I’d really appreciate it.
You can add it with a new update.
Because not everyone uses them. Google+, Pinterest, Soundcloud is not very important for technology sites.
Steam, Twitch, better. 🙂
We’ve noted your suggestion and perhaps in the coming updates those will be implement.
That you for your suggestion!
