Im using Ad inserter pro to show ads in my blog.
Problem: when I put an Ad after first paragraph inside a Cloud template, Its show the same Ad two times.
I disable all the plugins and activate one by one: tagDiv Composer is the responsible.
The blog: https://www.desdeelmurete.com/manguitos-caucho-reinyeccion/
Any idea?
Hello !
Unfortunately we cannot offer support for untested plugins. Ad Inserter Pro is an untested plugin and we cannot help you with it due to support policy: https://forum.tagdiv.com/newspaper-theme-support/
Also you can find inline ads for the Single Post templates from the Cloud Library into the tagDiv Composer here: https://www.screencast.com/t/zdF8pWIG9L
