Add more than 3 Custom Fonts?
Can I add more than 3 custom fonts through the Custom Fonts dialog box? It doesn’t appear you can… How might I add more custom fonts *maually*? -thanks!
By default the theme allows you to add only 3 custom fonts. However you can modify the code in order to add additional fields in theme panel. Please check this topic where my colleague Bogdan offed a solution: https://forum.tagdiv.com/topic/additional-custom-fonts-files/ The solution refers to Newspaer theme but should work on Newsmag as the code is similar.
