Adding Blocks inside Posts
Is it possible to add a block inside a post?
For example if I am posting an event space and I want to pull in all the event posts that are categorized under that venue how can I do that?
Yes, it’s possible if you will use the Cloud Template Library for Single Template. using this tool, you can use the TD Composer for creating your own Single Template, which is more powerful. Check the plugin documentation from here -> https://forum.tagdiv.com/tagdiv-cloud-library-plugin/
I’m sorry I was referring to adding blocks inside an actual post. I’ve used the cloud templates to add blocks in single templates previously however they are applied to all post pages that I assign that specific template to.
What I want to do is add a block lets say of all events and photos that are categorized to that particular venue. I don’t want these blocks to show on all posts only on that particular post about the venue.
So if I have 10 venue posts within each post I want to add events, photos, map affiliated only to that particular venue.
If you have already created a single post template for Venue, in your case, you should not assign it for global. You need to assign it only for your posts you want. Also, if you need 10 venue posts, probably you need to create a single template for each one.
Hope this helps!
We look forward to helping you!
Thank for your understanding!
