Ads do not save when clicking save
For some reason nomatter what I enter into any of the ads field they do not save. In fact no matter what I enter or any field I change in the Ads section, nothing carries over once I refresh the Ads section after clicking save.
theme version 8.0
Server software i nginx/1.13.1
PHP Version i 7.1.6
post_max_size i 160M
max_execution_time 60
max_input_vars 10000
SUHOSIN installed false
mbstring available
WordPress and plugins
WP Home URL i https://X.com
WP Site URL i https://XX.com
WP version i 4.8
WP multisite enabled i No
WP Language i en_US
WP Memory Limit 256 MB/request
WP_DEBUG False
clear cache and try again.
redis cache with nginx helper. Not working still.
http://imgur.com/54dfe05d-fa20-4ff9-a060-080cafba3115gif
  • This reply was modified 9 years by epicmatt.
Try increasing the max execution time. It is recommended to have a value minimum of what it is now. Increase it like this and then check again
Just tried this method as well to no avail..
Please deactivate all your plugins except the ones provided in the theme package, then clear any caching installed. Switch to the main theme if you are using a child theme. This will rule out any plugin interference, or modifications.
Lastly you could try a theme reinstall using this method
– https://forum.tagdiv.com/install-via-ftp/
Still haven’t gotten it to work, I checked error logs and no clues in there either.
Please send us an email at contact@tagdiv.com and provide your website, with admin login information. We will take a look and maybe identify why this is happening. Also paste a link to this topic in your email, so we can identify you.
