We just moved to a new ad system and we are facing an issue.
We put the – script async src=”https://cdn.fuseplatform.net/publift/tags/2/3328/fuse.js” script in the header ad unit thinking it will show in each page once the user scrolls down to another pages on desktop (infiniote scroll). However it is not.
We tried putting in the RHS ad unit as well as in a single external shortcode box also, placing it above the headline in the template. We tried the raw HTML script box too, placing it above the headline in the template.
Nothing seems to be working.
We asked the ad unit suppliers, they said –
“you already implemented all the tags on Infinite Scroll. But it’s not working because it’s inside iframe. Since it’s inside iframe it’s like a separate page and it requires a separate fuse.js header script.
The fuse.js header script needs to be loaded on each article inside the iframe in the <head> section like a new page.”
Please let me know where can we put script async src=”https://cdn.fuseplatform.net/publift/tags/2/3328/fuse.js”
So that the ads show in each infinite scroll pages as well.
Best Regards
SP
Website: http://www.gadgetbridge.com
Please set the code between in the analytics.
You need to set code here for mobile theme + amp https://i.imgur.com/2kAsROP.png
Thanks Ana for all your effort, much appreciated. can you please let me know what exactly did you do to make it work/ads appear in infinite load pages?
We have added the code only to the analytics/js code box and removed it from everywhere else. The ads are showing on the first page, but still do not show on the subsequent infinite load pages.
This is very odd for us.
In console we are getting this error.
This reply was modified 3 years by
SP1.
I checked and seems that you have set the code in body -> https://i.imgur.com/aqSMubH.png
please set it only in the head.
it is in the head area only.
https://prnt.sc/uA4qdqVxwFgA
SP1.
The errors don’t come from the theme. I think that is something with the code for ads, please check those guides https://groups.google.com/g/cookiecontrol/c/Fk_wPL0HriI?pli=1
-> https://stackoverflow.com/questions/74817843/why-would-tcfapi-not-be-defined-on-consent-data-ready
Thanks, for the errors, have already checked these pages out. The ad tech guys are saying the ads are not loading in the iframe of an infinite load articles of newspaper theme, hence the errors.
We have added the Fuse.js code in the head. But it is not executing on infinite load pages. Which is very strange.
Can you please ask other team members, why is this happening? As the ad codes should execute on all infinite load pages.
SP1.
I am stuck here, ad Guys say the script is not firing in iframe of newspaper theme in infinite load and you are saying its problem with the script.
I put it in the RAW HTML in the header. That did not work either.
I even put it in custom HTML.
Ana said she made it work, can you let me know how did that happen?
SP1.
We can check only via email. Please contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
We will take a look and try to help you asap.
I don’t know, but it seems you have broken something with the latest update. I have a similar problem with AdSense in my site, too. You don’t accept, but many of problems are related to your theme.
Ditto.
To test out we just went back to Google Adsense setup and they are also now not loading on infinite load pages on desktop.
Please look in to this, after latest theme update none of the ads including Google Adsese are loading on infinite load pages.
SP1.
Same issue on our other websites running Newspaper theme with Google Adsense.
including
https://motorbridge.com/
https://www.gadgetbridge.com/
The ads are also not loading after the latest newspaper theme update on infinite scroll pages anwywhere.
So this is definitely an error from the Newspaper theme end and not anywhere else.
Please provide a solution.
Team, we need a fix please.
Even in the latest theme update it has not been fixed.
It is a revenue loss for all of us.
Am sure others are also facing revenue loss, if we cannot display ads revenue is being lost every minute.
Please give a temporary solution if not a permanent one till next update.
Hi, we are also experience the issue with no Google AdSense ads on infinite scroll posts.
Did you find a solution for this? I just updated the theme to the current version, but still no ads on infinite scroll posts 🙁
The only think that I have in my mind that can interfere with that option, I think that re the new theme option core optimize the css theme from the theme panel – https://i.imgur.com/6rDEtYy.png disable both options and clear the cache, after that check to see if there are some better results.
Thanks for you fast reply Calin, but this did not fix it 🙁
Must be something else? And it seems like multiple people have the same issue.
There is only blank space / white space on all the ads placements on the infinite scroll posts.
This is financially hurting our website a lot every day, so we would really appreciate if you can look further into this issue and help us out.
