Ads not loading on infinite scroll article pages. need help
I understand. If you agree, I can take a look at this, but it will be need to contact us via email at contact@tagdiv.com and provide a link with temporary wp-admin access to the website – https://www.wpbeginner.com/plugins/how-to-create-temporary-login-for-wordpress-no-passwords/ and provide a link of this topic to can identify the situation faster.
As a temporary solution, the only thing that can be done is to disable the option to load infinite posts.
Great, I have sent you an detailed email now.
Any updates on this? (Still no response on my email)
I investigated the case, but the problem is quite complex due to the fact that the posts on the loading page are loaded in a new iframe and the google AdSense code is usually no longer applied inside them – https://support.google.com/adsense/thread/149874717/can-we-use-iframe-in-my-website-with-google-adsense?hl=en
We made test with static banner and those are working ok.
We also written to AdSense to see if there is an workaround for this situation, but for the moment we didn’t got a reply.
Hi Calin
Why are infinite posts on scroll loading with iframe? I can see other themes for WordPress with similar infinite scroll post function shows ads in them. So either do they not load in iframe (but still have the same function) or the argument with Google Adsense not showing ads in iframe is not correct (as it clearly shows in a different site I just checked).
I’m not sure about the specific characteristics of other themes that offer this option, but I took the opportunity to create a task and had a developer examine the source code of 2-3 themes that provide fine scrolling. Our goal was to identify any differences in the implementation and explore the possibility of incorporating similar functionality into our theme.
Your understanding is greatly appreciated.
Hi, still waiting for your response here (via support on email).
As mentioned there I have found another website using this exact same theme AND showing Google AdSense ads in the infinite loading scroll posts works on that site.. so surely Google canno’t be the problem here.
We have been struggling with this problem for a long time, please find a solution. In any case, it’s good to see that I’m dealing with it, because it’s leading to a significant loss of revenue.
Yes, true it is a significant revenue loss. Hope @Calin and the team can find a solution soon as we tried it on a few other competing themes on our partner websites and there the infinite scroll and Google Ads work superbly well.
The developers have analyzed, and unfortunately, it is no longer possible to run Adsense in iframes.
But your own theme DO run Adsense on a different website I found.. So I’m having a hard time accepting that answer without any further explanation on how come Adsense shows on the mentioned website, with this theme?
As far as I know they use Google Adsense, as when looking at the sourcecode they have the same script from Adsense as we do. (FYI: Adsense uses “doubleclick” in URLs from Adsense scripts and ads).
(Please hide the URL to the mentioned site, as I would assume they don’t want it visible like this. Thanks)
thanks, Ana, then for future update my feedback is to find another way of infinite loading. Other themes on Envato have infinite load and the ads are working there, even on mobile sites some themes have infinite load with ads.
If users are not able to display ads within your theme, then why will one go with Newspaper theme?
Something needs to be done in the near future update, my strong feedback as we have been using Newspaper for 8 years now.
Again thanks.
The The first thing that needs to be checked is if you have any errors in console related to ads when the next post is loading using the infinite scroll option, if there are errors related to ads those need to be fixed to can display them, example of errors – https://i.imgur.com/j65YF9P.png – https://i.imgur.com/DWCY6ly.png
This is the error we get in the console.
https://imgur.com/oOskHXX
https://imgur.com/3CdeQyG
As checked on two different article pages.
Also, is infinite load available in Mobile theme?
  • This reply was modified 2 years by SP1.
Hi SP1,
Yes, those errors seems to be related to ads – https://i.imgur.com/zL6X6JI.png
The infinite load is only for responsive version (the mobile theme plugin does not offer this option).
Yes, exactly. They are not loading in any page in infinite load accept 1st page.
This mistake causes me to lose a lot of income. I was using a different theme. Publisher theme. Since the theme was closed, I switched to Newspaper theme. Publisher theme didn’t have the issue of not showing ads on infinite posts. However, in the Newspaper theme, ads do not appear during infinite uploads. Unless this is resolved I’ll have to switch to another theme.
I agree completely @SP1. I was using Publisher theme. I’ve never had a problem with ads not showing during endless scrolling. However, in the Newspaper theme, my sites experienced an incredible loss of income. Ad click-through rate dropped to 1%. The first priority of those who buy this theme is to earn advertising revenue. Therefore, this problem is the first to be solved.
For example, in this theme, ads are loaded on pages with infinite scrolling feature.
  • This reply was modified 2 years by Calin.
We understand what you are saying and we agree that it will be better if the AdSense ads will work with our option for infinite scroll on articles.
@mostwonder
I edited the last last reply, you can mention in our forum about other themes but it’s not allowed to post the link to them.
Thank you for your understating!
Thanks @Calin, hope it can be taken as top most and tier 1 priority. As revenue is extremely important for each and every publisher and this has been lingering for a very long time now.
Looking forward seeing this solved soon.
We’re working on making AdSense ads compatible with infinite scroll, or finding a different way to do it without using iframes. Your input helps us improve!
Thank you for your understanding and cooperation!
I work with Google Adsense and OptAD360 advertising company on my website.
Adsense and OptAd360 ads are displayed on the first page that opens.
However, only Google Adsense ads are displayed on the following pages. OptAd360 ads do not appear.
If I add OptAd360 ads to the transition area between two pages, they appear.
But they definitely do not appear in the article.
This leads to a serious loss of income.
OptAd360 advertising company says that this is related to the theme I use and that all publishers using the Newspaper theme have the same problem.
My English is very poor so I apologize.
Viewing 25 posts - 26 through 50 (of 58 total)
