I am using ACF Pro with the Newspaper theme. I am running into the issue that when I use the regular (non-pro) ACF fields they all seem to work and display correctly. However, when I used a PRO field (such as the repeater field), the theme does not display the output correctly. It’s not outputting it as an array, thus it just showing commas on the page and not the content.
Screenshots:
https://drive.google.com/file/d/17FKiMXiSnaL33mQgOv9Yp0mQzGtU_yC8/view?usp=drivesdk
https://drive.google.com/file/d/1xF_l66DKIM5iUFPCLQ5HsZRxtup5FHbX/view?usp=drivesdk
Hello @maguari !
Check out this thread: https://forum.tagdiv.com/topic/acf-extension-issue/
Hi! Thank you for your response. I saw your comment in the other ticket. However, I am using the built-in shortcode for Advanced Custom Fields and it’s not working with any of the Pro features (such as the repeater field). I tried using the column text with the shortcode the way you mentioned and it just outputs the word “Array” instead of the content listed in the fields.
Hi maguari, we made some tests, and the Advanced Custom Fields seem to work. If you want, we can take a look together, please contact us via email at contact@tagdiv.com and please provide temporary wp-admin access and let us know the page for tests you have, or if you have a staging will be even better 😀
