Ajax filter problem
i got problem with ajax filter on my page. I switched it of at the moment but when i switch it on, the content wont show.
Here how the problem look like
ajax filter wont work
http://wstaw.org/w/3FRS/
my web
http://meteoserwis24.pl
Problem started when i installed nwespap 6
  • This topic was modified 11 years by pablito.
Newspaper 6 is a totally different theme from version 4. We changed all the code to have a cleaner smoother theme. But unfortunately this affects users that have custom modifications done as they will not work anymore. You will have to remake your customizations (if you have any) and adjust them to the new code. Also a few plugins that worked in the previous version (4) might not work in the current one. So please try your filter without any plugins as well to rule out a plugin conflict.
Sorry for the inconvenience.
Let us know how it goes.
HI,
i switched off all of my plugins and problem didnt disappeared. I also noticed that all page works more slowly than it was earlier
Please update your plugins as well. I see you use an old version of visual composer. Try to update the plugin https://forum.tagdiv.com/how-to-update-visual-composer-plugin/ and if the problem is still there,
please send us an email at contact@tagdiv.com with your login information so we can take a look and figure out a solution. Also include a link to this topic so we know who you are and what the problem is.
