Ajax load animation color
How can I change the Ajax load animation color? I have changed the general theme accent color but the Ajax load animation color hasn’t changed. It stays blue. I changed the theme accent color to red but this change did’t apply to the Ajax load animation color. How to fix it? Thank you in advance!
In blocks pagination it will be the theme accent color by default
– http://prntscr.com/o3u3dh – http://prntscr.com/o3u390
If a color is set for the title background in the composer – http://prntscr.com/o3u3uc
That will be the color used – http://prntscr.com/o3u4b3
In other places such as category pages for example, when the infinite load is used, the theme accent color will be used.
What is happening in your case? Post a link to the website so I can take a look.
Let me know.
Thank you for your quick reply! In my case I want to change the pagination color in the section of the subcategories (in the header) to red (red is the accent theme color) but it stays blue although I have changed it in the section for the colors. This my website: http://armswatch.com/
That should work as well, it should inherit the theme accent color. For example
– http://prntscr.com/o47pzf – http://prntscr.com/o47q40
I see you are using an older theme version, but as far as I can remember there was no issue in this matter.
Try clearing all the caching you have, also if you have any minification plugins, deactivate theme temporarily. Then check again.
Thank you! I deleted the caching from my website using Super Cache Plugin, also from my browser, I don’t have any minification plugins but the Ajax animation color hasn’t changed (it stays blue) although I have changed the theme accent color to red. Is there any other way to delete the caching?
P.S. I figured out the problem – actually when I change the theme accent color this change doesn’t appear at all on the website. For some reason this option doesn’t work on my template. No idea why
The problem with the theme appears bigger – I can’t change anything in the header. For instance, I don’t want a sticky menu but it stays sticky (on the desktop version). The mobile version is OK. The mobile version shows the changes unlike the desktop version of my website. I deleted the browsing data, tried other browsers so it is not the browser. It is even worse – I tried to see if the option for the opacity of the background image works, applied the change, it worked but now I can’t undo it. I remove the opacity in the settings but this change still appears on my website.
The problem with the opacity was fixed but I’d better not change anything anymore. Not sure if I can undo it or not. The theme seems to not work properly anymore.
Please make a test, clear all cache and deactivate all plugins and let only the tagDiv Composer activate, after that try to make some changes in theme panel and see if those are apply, it is possible to be some incompatibilities between theme and the plugins that you have.
Also please make sure that all the settings are like in our requirements, please follow the guide carefully
