Akismet vs SpeedBoster Problem
Hi, I am using akismet but speedbooster is not working because of akismet. Should I use speedboster and disable akismet? or akismet is good?
The Speedbooster plugin has an inbuilt plugin checklist, if it detects plugins outside that list it will deactivate itself. This is supposed to happen, as the Speedbooster plugin could cause some plugins to not function properly.
The checklist could be disabled by modifying the plugin code
https://forum.tagdiv.com/topic/tinymce-advanced-and-other-various-disabling-speed-boster/
Then tests should be made to see if everything works properly.
