Tinymce Advanced and other various disabling speed boster
Disabled – incompatible plugin detected: comments-from-facebook/facebook-comment.php – Tinymce and – WP-Optimize – Google analytics by Yoast – author image.
What are the compatible plugins? Can I disable the tagdivspeedboster? or this will affect the speed?
The speed booster plugin does not work for you at this moment so disabling it will not affect anything. The plugin has a list of compatible plugins in it’s code and if any plugin is found that is not on that particular list it is programmed to shutdown.
This is the compatibility list: https://www.screencast.com/t/hcjLnOqh4i2
There is however a workaround if you truly wish to use speedbooster with your current plugins, you can make it work by removing or commenting out this code here: https://www.screencast.com/t/RZLIOPUNdqh
This method is not an official position and it could create problems with certain plugins.
You can use this link to achieve faster loading speeds: https://forum.tagdiv.com/how-to-make-the-site-faster/
And you can use Better WordPress Minify and Autoptimize who make (i think) the same thing and are compatible with many other plugin or you can easily deactivate those not compatible inside this plugin.
i tried all you said for my website http://naijabambam.com/ but its still slow
Are you sure you followed the guide exactly? https://forum.tagdiv.com/how-to-make-the-site-faster/
Optimize images – point 3 of the guide: http://screencast.com/t/m7noLNKj3V
Render blocking js and css – point 5 of the guide – http://screencast.com/t/pA3Vk9lIk
Leverage browser caching point 2 of the guide – http://screencast.com/t/BHVwcxuHY
You are not done with the optimization.
deleted comment
Please can you update the screencast for disabling the plugin check for booster.
Disable plugin check
mine says: v4.9.3 – Disabled – incompatible plugin detected: buddypress/bp-loader.php
Isnt Buddypress one of the plugins that are supported/compatible?
Indeed Buddypress is a tested and recommended plugin to use with our theme but The speedbooster plugin will not work with all plugins tested with the theme itself. The speedbooster plugin has limitations and will not be able to move resources for all the plugins even if they are tested with the main theme.You can use the method posted in this topic to remove the message and keep the speedbooster plugin active.
v4.9.3 – Disabled – incompatible plugin detected: accelerated-mobile-pages/accelerated-moblie-pages.php
But i need speed booster to be activated, But still, AMP is important we can’t remove. Is there any way to speed up my site https://ww.premiuminfo.org
@duraijeeva
The website is offline at the moment – http://prntscr.com/mk29ot
Our speedbooster plugin is an optional plugin that works/is active only for some plugins, unless making modifications in it’s code.
Note that there are other optimization or booster plugins that you could try. I can’t make any recommendations because we haven’t tried any.
Test the website with website speed assessment tools and fix as many issues as possible. Check this forum as well, there are guides provided by theme users in this matter.
Can you check again it’s online, I don’t know what was the issue while you checked.
I still cannot access it at the moment – http://prntscr.com/mky1nx
What AMP plugin are you using? if you use the AP plugin provided by us, the booster will not deactivate when it is active. If you use the default AMP plugin you could add it in the allowed list – http://prntscr.com/mky2x2
Then the booster will be active – http://prntscr.com/mky3be
Feel like issue from your browser, I am using AMP by Ahmed Kaludi, Mohammed Kaludi
Site is not loading dude to cache issue from your side, it works perfect here.
I tried in multiple browsers, still the same in my case – http://prntscr.com/mmk6uj
Try to add that AMP plugin like so, in the speed booster plugin code
– http://prntscr.com/mmk85l
'accelerated-mobile-pages/accelerated-moblie-pages.php',
Then that plugin should not deactivate the speed booster.
Where is the method to activate the speed booster plugin?
Hi @aamirmehmood7000,
You can find the documentation for speed booster plugin in How to make the site faster
Thank you!.
iam using Newspaper9,
i cant edit using tagdiv composer in my live website, while edit it shows Ooops error 404 Sorry, but the page you are looking for doesn’t exist.
how to solve the issue?
Please Help.
Please make sure that you still have that page/post, also please check the page/post url and save the permalinks -> https://www.screencast.com/t/QdofmGTW after that clear all cache and try again.
Please make sure that you do not have a plugin conflict with untested plugins, please deactivate all non theme/tested plugins, also if you are using child theme, clear all cache and try again.
Viewing 19 posts - 1 through 19 (of 19 total)
