Amazing Theme! But after setup my page speed is very low.
First of all i am very exited about Newsmag theme πŸ™‚ Really exited πŸ™‚
Thank you developers πŸ™‚
Here is my page sample: http://www.mobee.lv
Unfortunately now after first setup my page works in very low speed level:
27 / 100 mobile
35 / 100 desktop
I am not advanced user and i don’t know how to improve my page speed.
Have you any solutions for beginners?
Thinks gets better πŸ™‚
66/100
83/100
But anyway, how can we go beyond the orange zone?
Thanks in advance πŸ™‚
Test one of your post pages at GTmetrix.com as this will give you very good beginner instructions on what/how to fix the basic stuff — much better than Google’s help (or lack thereof). πŸ™‚
Please use our theme documentation and follow the instructions provided in our page speed guide: https://forum.tagdiv.com/page-speed-guide/
Please note that recently we have tested the theme withe the Wp Super Cache plugin so we recommend it instead of the W3 Total Cache which has lot’s of settings and it’s more difficult to be used properly. Make you use the default settings for the Wp super Cache.
If you don’t have basic coding experience and you’re not aware of the steps you need to do regarding page speed we suggest you get an experienced wp user to do it for you.
and of course my handy dandy suggestions for speeeeed can be found here:
https://forum.tagdiv.com/topic/tutorial-chriss-custom-optimizations-for-functions-php-etc/
Hello Guys,
This was a crazy day. Results the same in my page speed field πŸ™‚ But what an expierence… πŸ™‚
After i change the function file as Cris advice i lost control over my admin. For some moment all what i saw in front of me was blank admin page πŸ™‚ But page in browser works good for some reasons, even GTmetrix show results as 100 / 100 and 100 / 100. Google Speed Test show eror to fetch page. I lost control over site πŸ™‚ Than i realise that i can change back function file through file manager. I start go step by step as Andrei advice: https://forum.tagdiv.com/page-speed-guide/ but all about JS for me is too new and i am in the same place where i start πŸ™‚
Anyway Guys, thanks a lot for your time and my first experience in WP speed world.
My target is the same, improve my page http://www.mobee.lv loading speed πŸ™‚ …
Can someone explain what to do with this message in system statuss?
Speed booster: v4.1 – Disabled – incompatible plugin detected: googleanalytics/googleanalytics.php
Hi Aldis9,
If you are not ware of the steps and the instructions you need to follow to improve your site’s page speed score we advice you to seek experienced help because this is not recommended for unexperienced users so it would be best.
The speed booster plugin has been designed since it’s forth version to disable itself it detects an active plugin that it’s not from this list: http://screencast.com/t/Em0O14Bb
Please see this post if you want to add other plugins to that list: https://forum.tagdiv.com/topic/speed-booster-problem-after-update/#post-58973 and this topic for more detailed info: https://forum.tagdiv.com/topic/speed-booster-not-working/
