Hi.
We already use a template but we have a problem. Can I ask you for help? It is about the MenWorld.pl portal.
We want to divide the website into the one with PC and mobile. I mean, we want the PC to show the normal version and the phones to show AMP. I think I’m setting up something wrong. Sometimes AMP shows up on the PC and the phone shows the PC version. I can’t change it. Can you help me?
Additionally, I have a question from our SEO expert.
“After the implementation of the new template, the structural tags for entries were duplicated, the problem is so significant that the latter points to addresses other than the default website address,
that is:
https://menworld.pl/final-ms-w-siatkowce-polska-vs-wlochy-gdzie-ogladac/template-id-63544
referring to page 404.
I recommend that you submit a template to the support asking if it automatically generates any structural schema data responsible for articles. If so, how can they be removed, because they duplicate those generated by the RankMath plugin. Additionally, one should ask why the template-id addresses are generated for entries next to the structural tags, because they started to generate after uploading their template, and on the demo versions presented on their website, I can see that all data is generated correctly. ”
Hi menworldpl, normally when the mobile version is displayed on pc and vice versa, then it is a cache problem.
We recommend to use a cache plugin that offer mobile cache support. For example WP Super cache, also WP Rocket offer this option.
About the schema, if you are using the one from the RankMath then please disable the one from theme using this option -> https://i.imgur.com/mIXvPJU.png
Hello! Thanks for your message. So, I use LiteSpeed Cache and I found options for mobile users. I hope that now everything will be ok. 🙂 About Schema – thanks a lot for suggestion. BTW, maybe you can view our website (menworld.pl) and check whether everything is ok about SEO options?
