AMP only works on the home page
https://prnt.sc/rav9qb
on other pages does not work
https://prnt.sc/ravb74
These are my AMP settings.
https://prnt.sc/ravchh
https://prnt.sc/ravd9w
after disconnecting all plugins except TD composer and AMP, the following error occurred
https://prnt.sc/ravfnf
And these errors are given to me by the search console
https://prnt.sc/ravhwe
Hello !
This may be caused by one of the plugins that you use.Please make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
I wrote in the text, I deactivated the plugins … and clearing the cache didn’t help … look at the screen, what errors occurred after disabling plugins except TD composer and AMP
This reply was modified 6 years by
denya.
Hi denya,
Please use the mobile theme plugin with this option for amp -> https://i.imgur.com/3Igfb0a.png this should fix the problem.
Let me know the results!
only pages do not work
records work
In AMP settings, all items are checked
denya.
In order to have content in amp pages, you need to set it in mobile editor, using only the elements from mobile editor -> https://www.screencast.com/t/ebUIzt4se -> https://i.imgur.com/uYydAwp.png -> https://forum.tagdiv.com/the-mobile-theme/
Hope this will help you!
