AMP problem all links are invalid
I updated the theme and followed all the instruction also related to AMP and everything work fine. BUT getting error in google search.. All the article having same issue.
Now I am getting this error: https://prnt.sc/mv3p6x
Here is my AMP setting : https://prnt.sc/mv3ps5
Lot of Issues in new version
I was also AMP viewing Validated URLsView
this is how amp version is looking.. I have no cache plugin activated : https://prnt.sc/mv4dps
This update things really messed up… Mobile Theme intregrated with AMP bad move… site is not looking good I had to deactivate AMP with mobile theme..
Besides the fact that you have activated the amp, you also have to activate the mobile theme and then activate the AMP functionality from here -> https://www.screencast.com/t/7iyT8SMWnkVB Also, for more information about the functionality of AMP with Mobile Theme, please check the following useful guide from here -> https://tagdiv.com/amp-newspaper-theme/
The initial AMP plugin we released was designed based on the first version of the official AMP plugin for WordPress. Even though it was a tagDiv plugin, it still required the API of the official plugin. The changes came from the official plugin as they limited the theme support in the version we used and instead of updating it, they launched a new version with another, better implementation. They also announced the initial release will shortly become deprecated. This is why we decided to abandon our initial AMP plugin and use the new AMP implementation through the mobile theme. The new version required a specific theme for it as it would not have worked through the standard theme. There was no decision to take, unfortunately. If we have not made this step, soon the AMP plugin would have stopped working once the official AMP plugin implementation we used became deprecated.
For more information about this functionality, please check here -> https://forum.tagdiv.com/the-mobile-theme/
I look forward to helping you!
Thanks for oyur understanding!
I have done the same way.. I activated the mobile theme first then activated the AMP…
I checked your website, seems neither the AMP plugin or the mobile theme are active. In order to test if AMP works please enable them both, then the setting in the theme panel.
After doing this, test a post in the AMP validation tool
– https://validator.ampproject.org/
The link when testing with the tool should be like this example
https://www.androidhire.com/google-allo-is-shutting-down/amp
Let us know the results.
I have to disable the AMP version because it was creating lot of mess, all the link getting error in google search.
I have kept mobile theme active only so that loading time boost. Thanks for looking in this.
But I think many users are facing this AMP issue.
The theme has hell lot of issue in AMP. Unfortunately the support staff just play the same old story without actually fixing the issue.
I followed exactly what documentation says and still all my links are invalid in Google search. Waste of money and time as I bought this theme.
@aditya58singh
, if you encounter any errors with the theme regarding on this section, you have to send us an email at contact@tagdiv.com with your log-in information (wp-admin) and provide CPanel access so we can take a closer look at it. (the same thing is available and for @mimicreature). If you are still unhappy with our theme, please request a full refund here-> https://themeforest.net/refund_requests/new and we will approve it as soon as possible.
