AMP problem with Tagdiv mobile theme
Hi!
For long time I had no problem with this theme and plugin, but I noticed a few week ago that the AMP plugin only runs in transition mode. If I set to Standard, the plugin switch back to transition.
I thought I would turn it off and reset it. Since then, if the Tagdiv Mobile theme is turned on, AMP will not appear in the menu and there is no setting, just turn it off on the plugin manage page.
What can I do?
The page: https://hirmagazin.eu
Balazs
In order to avoid misunderstandings, please provide more information about what exactly you need to achieve, screenshots or a video.
Hello Bettina!
I made a video with Nimbus and Chrome. The link: https://drive.google.com/file/d/1XtAqLcVziDru_vy0Qdzg7T6uC_qdTtdi/view?usp=sharing
In this video you just install and uninstall the AMP and Mobile Theme. AMP is faster and works better only with Mobile Theme plugin. From my point of view, if you don’t use the Mobile Theme plugin, then there is no reason or benefit from AMP. Please read all about AMP here: https://forum.tagdiv.com/tagdiv-amp-plugin-tutorial/
No. I activate and deactivate the AMP plugin, then deactivate the Mobile Theme plugin (30sec) and activate the AMP plugin. In this case works well the AMP plugin, can use the settings menu. After this (50sec) I activate the Mobile Theme plugin, then the settings menu, and the full AMP menu goes away. I show this in this video. As if there were a conflict between the two plugins. There had been no such problem before.
I want to use both of this plugin. This is the goal, but in this time I cannot. If both is activated, then the AMP plugin settings page gone away.
When you use Mobile theme + AMP or AMP, then you will have the settings there: https://prnt.sc/KfpBlGorH-gN
Thanks for re-enabling the AMP plugin, the setup wizard has appeared and this part has been fine ever since. But I can’t switch to another mode, it always goes back to Transitional.
Why?
https://photos.app.goo.gl/VYw2qZN3HqNxmjF3A
Yes. Please check this from our documentation: https://prnt.sc/bcM2YbArh1wY
So Tagdiv needs to be on Transitional AMP? Because every time I set it to Standard in the AMP plugin, it reverts back to Transitional.
Yes, you need to set the AMP to Transitional, like in our guide -> https://forum.tagdiv.com/tagdiv-amp-plugin-tutorial/
