AMP problems
I just activated mobile theme plugin and amp as explained in this.
But when I access to site from a mobile device sometimes the amp pages appear, sometimes mobile pages. And there is no ?amp suffix on amp pages. When I use validator tool, it dosen’t validate any of them.
If you are using the Mobile + AMP the AMP design will be like the mobile theme design.
Also for the url/amp appear in source page, so google will still detect it.
for example:
-> https://www.screencast.com/t/HZ3jffxn4a
Please provide me a link were I can make some deep investigation, in this way I will be able to provide you a better answer.
Hi.
This is my site. I have another issue with images.
WP_MEMORY_LIMIT try to increase it at least to 256mb.
Also please check the php version to be 7-7.2
Please make sure that you do not have a plugin conflict, please deactivate all non theme plugins, also if you are using child theme or cache plugin, please deactivate them, clear all cache and try again.
I check your amp post with validator and thos pass the test -> https://validator.ampproject.org/
I checked your website and you have some 404 errors in console -> https://www.screencast.com/t/R2SMDtzU2
Please check those articles for How to Fix Error 404 Not Found on Your WordPress Site -> https://kinsta.com/blog/error-404-not-found/
How to Fix WordPress Posts Returning 404 Error -> https://www.wpbeginner.com/wp-tutorials/how-to-fix-wordpress-posts-returning-404-error/
How to Fix 404 Error on WordPress Posts and Pages (3 Methods) -> https://www.hostinger.com/tutorials/fix-404-error-wordpress
Hi. I’ve a new problem with AMP. What ever I choose Mobile, AMP or Mobile+AMP it always shows AMP site on mobile devices. I can use mobike theme only by deactivating AMP plugin. I need to use mobile theme, not AMP theme. What should I do?
Since AMP has been retired by Google in 2023, ideally just stop using AMP at all, as Google will eventually turn that off, and at this point entirely, um, pointless. 🙂
(I don’t work here.)
The theme itself forces to ıse it.
I heard the same thing about Google retiring AMP. Thank you for confirming this. I agree it’s not really necessary, as back in the day when themes were less responsive to mobile.
Hi kasirga, “What ever I choose Mobile, AMP or Mobile+AMP it always shows AMP site on mobile devices. I can use mobile theme only by deactivating AMP plugin. I need to use mobile theme, not AMP theme.” – if you are using the amp version please make sure this option is disabled – https://i.imgur.com/BZ5LOyu.png
Also, when tagDiv mobile theme plugin is used you’ll also need to use a cache plugin that has mobile cache support, to can deliver a different cache for mobile users and desktop users.
