Article Inline Ad Problem
Hey there,
I just want to change my ad’s than I discover some problems.
I remember that I had earlier the possibility to set after which paragraph and on which position (left, middle, right) the “inline ad” will be shown. The possibilty seems to be off.
Also if I renamy the ad title it don’t change in the front-end (also with “Article Top Ad”).
I already clear cache, but the same problems.
What are the reasons? Thank you!
– Simon (www.awayfromlife.com)
Also the “More Article Box” don’t work on the Firefox browser (on IE und Chrome it works)
Hello AWAY FROM LIFE,
First of all, you should make a full backup to your data and there you should delete the old theme and install if from scratch via FTP because this is the surest method in this regard. For more information about this, please consult the documentation here -> https://forum.tagdiv.com/newsmag-install-via-ftp/ Also, after this, if your problem is still there, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) and full FTP Access so we can take a closer look at your website and also, so I will be able to provide a more accurate response. Also, provide there the link to this topic so we can quickly identify you.
Thank you for the message!
If I delete the old theme and install it new, get there informations and configurations lost? Like the settings of the themepanel, the widgets and so on?
Before every update, you should make a full backup to your data to be more safety. So, please notice that all the posts and pages which you have created on your website have been loaded to your database.
I install the theme new but the problem is still there. What can I do to solve the problem?
Unfortunately, we have a mini bug in theme regarding on the Ad Title. It does not apply the ad title, sorry! I have added this issue to our list of improvements and we will consider to fix it in near future updates.
Thanks for your understanding and sorry for the inconvenience!
